How to change hidden line scale in drawings?
I'm looking for a way to control the display (or scale) of hidden lines in different drawings.  I've found the option plot_linestyle_scale, but this globally changes all drawings.  What I’m kinda looking for is like the AutoCAD command ltscale. ????
RE: How to change hidden line scale in drawings?
Well mate.... you can do by two different ways:
first of them, you may create a view by picking the option "scale view"in the "add new view"... then you may scale each view separately.
For hidden lines, you must go to the Views -> Disp Mode -> View Disp... then you will have several options, like wireframe, hidden lines, tan dimmed, tan solid, show skeleton, hide skeleton, and many others.... try everyone to find the expected effect you want.
Hope I could help you!!!
Fabiano.
