PWHT OF JOINTS
PWHT OF JOINTS
Hey what's up.I would like to find out if it is possible to PWHT 2-24" butt welds 1" thick and produce a graph without any deviations i.e. from start to soak to cool down and all the tc wires that were recorded were one on top of the other.thanks
RE: PWHT OF JOINTS
RE: PWHT OF JOINTS
RE: PWHT OF JOINTS
RE: PWHT OF JOINTS
RE: PWHT OF JOINTS
The answer to your question is yes, you can come up with a very uniform chart. I have seen quite a few in this manner.
1) How close in proximity were these joints?
2) Were they pipe to pipe or were there differences such as a weld to a valve (more mass)?
3)Location and environmental conditions or Inside? Lots of variables come into play with PWHT. If you havent been involved in the field I suggest froming a close association with the PWHT Techs in the future. Look listen and ask lots of questions. This experience will serve you well...
From a personal standpoint, I have seen quite a few charts which were excellent runs. Ive also seen them run all over the page(stuck contactor, Bad UDC, or just a inattentive tech doing a dialup. Was this an Automatic runlike a Coopermaster or PC controlled or was this one run by hand? Unless there is some specific reason to question this PWHT I would offer to Brinnell test the weld and HAZ (at customer expense of course). I dont however understand why you wait so long before you start the recorder (chart paper is cheap)and the run up will allow you to evaluate how things are going. There should be TC# printed along the chart
4)BTW how many TC were on these joints and were the welds in the vertical axis or horizontal axis.(Inquiring minds like mine want to know)
A final note and Ill stop rambling for the meantime... As far as the charts go it helps for a field inspector to initial the chart in the field during the run to help establish that the chart turned in is the real Mccoy. Good luck, write back if you need any other questions.
Steve
RE: PWHT OF JOINTS
