Baldor Parts and Info Needed
I am working on a Baldor Motor, and now I need some help.
3HP
single phase
230 Volts
19 Amps
184 Frame
Where is a good place to order parts from? I need bearings and capacitors. What kind of capacitors do I need? The numbers are all gone. The capicators look like 2 start capicators, and one looks like a run capicator. Can this be? The one that looks like a run capicator exploded, so something was wrong. Thanks for any and all help.
RE: Baldor Parts and Info Needed
hi..
you can visit the website of baldor at www.baldor.com
if you can get their catalog..better
a reputable motor repair shop should be able to help you if cannot contact baldor or any of their representative...
dydt
Suggestion: Please, would you post the rest of the motor nameplate.
Ok, this is what I have:
Spec   36F15-2386
Frame  184     646LC
HP     3
Volts  230
Amps   19
RPM    1725
Cycle  60
PH     1
Class  F
Ser.F  1.0
Des.   L
Code   K
Rating 95C
Cat No L3610-M
hi..
in 646LC, LC denotes capacitor start and
capacitor run ( 2 values of capacitor)
...for 184 Frame bearing being used is double
shielded...
other info you have to contact your baldor
representative
good luck
dudt
This motor appears to be unlisted in Baldor Public Offerings, Catalog and Website
