API Tanks Secondary Containment
I am haveing a problem with water running down the side of the tank and entering the interstitial space between the liner and the bottom of the tank. The liner is sandwiched between the the tank and ground with asphalt impregnated fiberboard as per API standard detail. Has anyone else had this problem?
RE: API Tanks Secondary Containment
Thanks, my email is terrythompson@sprint.ca.
Terry
I am interested in how you get around this problem also. Would you be so good as to email me the Matrix detail.
My email is warwick@cosl.co.nz
Coslite
