Corrosion resistant plating on steel electrical contact.
I am looking for a cost effective (cheap) softer alternative to nickel plate on a mild steel (C1008) electrical contact. The contact can experience voltages to 600VAC and current to 38A.
RE: Corrosion resistant plating on steel electrical contact.
A bronze of 10-12% tin looks great (like gold) and is sometimes used for bearing surfaces.
