hello; What is the different bet
hello;
  What is the different between "decanter centrifuge" and ordinary "nozzle-disc centrifuge" ? both are for solid-liquid separation .
                                   Thanks for all replies
RE: hello; What is the different bet
"Decanter" or "scroll" or "pusher" centrifuges spin on a horizontal axis, have a spinning cylinder with a conical end and a flat end with "weir" holes for clarified liquid discharge; and an internal augur (scroll) spinning at a slightly different speed to push solids out the conical end. It's like having a dredge pulling solids out of a settling pond.
Decanter centrifuges handle more solids than the "nozzle-disc" centrifuge but the "nozzle-disc" machines have a greater removal of finer particles due to a greater area.
The "nozzle-disc" centrifuge typically spins on a vertical axis. The conical discs are like having an inclined (or lamella) settler subjected to a high gravity. Solids (with a little more liquid) are ejected through nozzles in the outer solid bowl. There are also "split-bowl" machines having upper and lower bowl sections that can be periodically and momentarily separated to eject accumulated solids.
Bird Machine builds a lot of the Decanter type; see cutaways at
http://www.bakerhughes.com/birdmachine/Products/solidbowl_pop.htm
Alfa Laval builds both types.
Great answer,Tom SD.Thank you
sorry, above thanks wrote by me, but from my coleague's computer !
