Find the size of nitrogen generator.
If I know the mass of liquid in the tank and want to completely take the liquid out with 4 bar nitrogen pressure within 6 hours,how can I start to find  the size of nitrogen generator?
 Thanks.
RE: Find the size of nitrogen generator.
Are you using the N2 to pressure it out?  Calculate the volume of liquid and that's the volume of N2 you need.  Convert the N2 (which will be at 4 bar) to standard conditions or whatever conditions you need.
I would prefer to consider tank volume and connected piping volume instead.To what height and length the liquid is to be piped? (4 bar may be high)
