Use of Admiralty Brass - High Temp CW Service
Does anyone have information regarding the use of Admiralty Brass tubing bundles in cooling water service (tube side @ 100 deg F) and naphtha service (shell side @ 150-300 deg F)?
A history of failures, fouling concerns, etc. is what I'm interested in.
RE: Use of Admiralty Brass - High Temp CW Service
Our problem is that someone decided about 20 years ago to replace existing Adm. bundles with carbon steel. This sacrificed a good life of 16+ years with a poor life of <7 years. And, this was replicated several times over that 20 year span.
Our CW system does have problems with flow, though I am unaware of the rate in this exchanger at this time. It's a systemwide problem that is being addressed over the next 18 months with upgrades.
My concern - being new to this field of corrosion - stems from a comment made by an "old timer" who seemed to remember problems with Adm. bundles at high temperatures. The only thing, I can't find any supporting evidence as such.
Thanks.
In my understanding, 150-300 degree F is not a high temperature service for admiralty brass.
I agree that Admiralty brass is better that CS for these
services
Thanks again!
Brent
