fault current calculation software
I'm looking for software for fault current or short circuit calculations.
This software is to allow the correct selection of the AIC rating for
electrical panels.
RE: fault current calculation software
Ben:
The electric utility you are connected to typically supplies the Available Short Circuit Current upon request.
If you are connected to a generator of some sort, the manufacturer specifications should list the AIC required.
DeWayne
A company called Technical Training Group (800-874-8883) offers a training course on this topic (Short Circuit Analysis). They have created a quick and easy method on how to do it. You may be able to call and buy the manual if you cannot take the course. The calculations are simple and straight forward.
Otherwise, try contacting some of the fuse manufacturers (i.e. Gould/Ferraz, Bussmann, Littelfuse).
Suggested software which are advertised very well on web sites are:
1. SKM, Inc. software called Dapper, A-Fault, Captor, etc.
www.skm.com
2. EDSA Power System Analysis Software by EDSA Microcorporation
www.edsa.com
3. Operation Technology, Inc. software called Etap
www.etap.com
All the above software are good, depending on your application and industry, and shall suffice for your needs.
Ben
I Suggest to use the ETAP software which is one of the most familiar s/w in this field.
Ben
I Suggest to use the ETAP software which is one of the mostly used s/w in this field.
There is a quick and easy spread sheet for fault calculations at mikeholt.com.  This spread sheet is set up to detrermine AIC for service equipment.  Get there by going to site map then to calculations.
Be warned this is a basic calculation that needs information to fill in the blanks and does not add motor contribution to the calculated fault.  It will get you to an AIC as quickly as any I have used and is betteer than using only the Utility contribution.
Suggestion to dspell (Mechanical) Jun 10, 1999 marked ///\\\
Ben:
///These parameters are good at the upper tiers of the power distribution system. Any power distribution downstream may need to be refined to establish lower fault levels and not to pay for unnecessarily expensive electrical equipment because of excessive short circuit currents or faults. Also, at some points, there may be motors that contribute to the short circuit levels.\\\
///Again, my above comment applies. Also, one must account for motor contributions of short circuit currents to the faults.\\\
DeWayne
can anybody tell me that from where can i down load ETAP software for free.
Lakshmipathi23,
Go to the ETAP web site and request the demo CD, you have no chance of getting the package for "Free"
Midos
Thank you.
ben,
ETAP is the software you are looking for to run SC analysis :)
lakshmipathi23
You can contact ETAP at 949-462-0100 for a free demo. I have used the software on a number of projects and is worth it if the project can justify the cost. Being modular you dont have to buy everything!
Atually i was looking for a free of version of this software
Dear Friends,
Can anybody tell from where i can down load a software which is same as ETAP for free.
Suggestion: The posted commercial packages by the major software developers, e.g.
www.skm.com
www.edsa.com
www.etap.com
are comprehensive software tools for the electrical power system modeling, analysis, computations, etc. They are fairly complex and expensive to develop and are not for free beside limited demo periods with some restrictions.
There may be proprietary expertise programmed in the software, e.g. algorithms.
The manufacturers, e.g. Siemens, Cutler-Hammer, General Electric offer their software packages with libraries including their equipment only.
