exploded blocks in a drawing
I recently expoded a block in my drawing of a delta symbol. Now the symbol is there and I can not select it to move it or remove it from the drawing. No matter what I try, I can not get rid of it. Did it become sketch entities? It also shows up on the drawing when I print...
Bob
Bob
RE: exploded blocks in a drawing
Mr. Pickles
Bob
Like DetroitPickles said you should try to find the view to which the symbol belongs. But this can be tricky because there are items (this happens often with axis) that can be selected only if they are inside of the view's boudary box.
If you have found the view and still can't select the items, they are probably outside the boundary box: extend the boundary box untill the items are inside of it. The items can now be selected.
I tried this before.. There are two views in my drawing. I stretched one out over and beyond the delta and still could not select it, then stretched it back and tried the other with no luck.. I think it is something to do with the blocks.
Try to activate the sheet (using RMB - Activate sheet or RMB - Lock sheet focus, if you are using dynamic drawing view activation) and then you should be able to select your delta (I suppose these are lines) and delete it.
Bye,
Stefan
unofficial german SolidWorks helppage
http://solidworks.cad.de
Shareware, freeware, tools and macros
http://swtools.cad.de
I can't help you, but I can tell you that I have run into the same problem a while ago. It shouldn't happen, so after reading you're thread and some of the answers that some supplied, I thought I'd give it another try:
What do you think: now it works! After exploding I can still select all the elements from the exploded block.
I think the blocks don't work as they should all of the time and that the programming-people who make the product still have something to do in order to fix this problem.
Aart
That's a new one for me.. Lock sheet focus and then I could pick the entities and delete..I will have to look this one up because I am not sure what lock sheet focus is..
Thanks again,
Bob
I didn't really fix it, or figure it out. What I did was checked my layers, then made sure it was on it's own layer (they usually are).
Then I deleted the layer! This is one way to get rid of it.
not the preferred method I'm sure, but it works to get rid of it if nothing else. I know it wasn't in a view boundary box, because I had none in the drawing.
Bob
