Panasonic VR 008 P11 AES
Problem: Wire feed burning back to the tip at arc end sequence. The problem is intermittant.
Have adjusted AES voltages, replaced tips, running 92/8 gas mixture. Welding 16 gage mild steel tube.
RE: Panasonic VR 008 P11 AES
CHECK WIRE FEED OFF DELAY
CHECK LINER FOR GRABBING WIRE (ARE THERE WAVES IN WELDED AREAS)
