text translator to convert autocad dwgs from spanish to english
anyone know of a way translating text from spanish to english.
RE: text translator to convert autocad dwgs from spanish to english
Well... You can use something like the BabelFish site to translate but you will have to pick out the text from the drawing manually and paste it into babelfish. We use AutoCAD Mechanical 6 and it has a built in translator, otherwise you would have to write a program that could compare your text in the drawing against a database of preferred converted text.
