Sketch centerlines invisible
I'm running SW2003, SP1.0. Since installing SP0.0, any skeych centerline is invisible. If I cursor over their endpoints, I can see those. I had no problem with any prior versions of SW.
My video card is a 3 yr old TNT, 16mb RAM using the driver recommended on SW's website. Any clues?
Thanks in advance,
Greg
Thanks in advance,
Greg
RE: Sketch centerlines invisible
Are you running with OpenGL? Go to Tools/Option/Performance/Software OpenGL. If the box it's unchecked, you are running with OpenGL. Check it, and try again your file. The graphic performance will be very poor but, if the lines are now OK, you confirm that you have a driver or graphic card problem (try another driver or change your garphic card).
Maybe you can solve the problem selecting lower resolution or color depth. Try other monitor settings (running OpenGL).
Good Luck
Definetly look at upgrading your card to at least a 32 card. I would say your problem is with the card. You could try running in VGA mode and if that fixes your problems then it's your video card.
Seymour
What OS are you using? That can effect crashing along with video card and other things.
Best Regards,
Scott Baugh, CSWP
3DVision Technologies
credence69@REMOVEhotmail.com
http://www.3dvisiontech.com
http://www.3dmca.com
*When in doubt always check the help*
What video card? latest drivers?
I read yesterday that some people have found that having a some different brand name Memory chips were causing crash problems. Sometimes Memory sticks go bad and this can cause crashing problems.
Some things to think about.
Best Regards,
Scott Baugh, CSWP
I recently upgraded from SW2001 to SW2003 SP1.0 and my 8MB card couldn't keep up. Upgraded to a 32MB card and the difference is unbelievable.
