FLUENT Ideal Gas Error
I have developed a model using Gambit 2.0 and have created a very fine mesh.  The problem is cold flow (non-reacting) with 2 species entering via two separate inlets into an expansion.  The problem ran well with the incompressible gas, however it does not work when I convert to ideal gas.
I have honestly tried adjusting everything (including multigrid settings) but upon the very first iteration, the solution diverges and says;
"Error on line 743 in amgif.c"
Any input would be appreciated.
Cheers
Jouch
