CPU at 100%
CPU at 100%
When opening 4 files in related to an assembly as soon as I try to manipulate something the xtop.exe causes the CPU to go to 100%? Are there some settings I need to check?
RE: CPU at 100%
RE: CPU at 100%
My computer at home gives a permanent 20% CPU usage even when no application is running. Kindly suggest.
Amish
amg@hitechesoft.com
RE: CPU at 100%
Incedentally, CPU usage and memory are not related. If you need to swap something into or out of memory, the CPU moves onto the next proccess while waiting for the disk to get done it's job. Virual memory causes no CPU usage. (The reason why it seems slow though is because you;re waiting for the hard disk, but the processes that can run are running)
RE: CPU at 100%
2.Dont use 1GB virtual mem for 512 RAM.use less.
Sleew
Compaq & Microsoft TS
mymailforyu@yahoo.com
