Outlet protection for 6" pipe
I am designing a storm water detention system which utilizes a horizontally run 6" PVC pipe as the primary outfall structure. Since the discharge is onto lawn, I need some type of difuser or splash guard at the outlet. Stone riprap is not desireable in this residential application. Can anyone offer a suggestion?
RE: Outlet protection for 6" pipe
flow wells-up from vertical riser
________________________
pipe * |
| clear stone trench
|_______________|
