Help (Hole in Cylinder)
Can you please help me?? Im trying to build a part which requires a hole to be drilled through the side of it and i just cant figure it out. Any suggestions. I am running Inventor 5. Please be descriptive as im am new with Inventor.
Thanks for you help in advanve
RE: Help (Hole in Cylinder)
Enter work plane command and press right mouse button on the screen. A visual help will appear and you can pick wich film to see about creating work planes.
After creating it, Crete a new sketch on it ang project the circular sketch for reference.
Hope I helped.
