Residential footings Caisson Design
I'm looking for a good source to design shallow (5' to 10') drilled concrete caissons to support residential houses. Most of the sources I've found deal with deeper caissons and larger loads. Any help will be appreciated.
RE: Residential footings Caisson Design
Shallow foundations pose special problems, though. How deep is the "zone of moisture influence" in your area? What is the accepted local practice? What about expansive clays? Collapsible soils? Liquefaction? Slope stability concerns? (Local issues not included in this laundry list?)
Often the design calculations to size the foundation represents the easy part!
