leak test procedures
I have tubes connected to each other to make one lin 20 m long 1/2" O.D , stainless steel , for transfering CNG in a feuling station , the working pressure is 200 bar.
I need to know the leak test procedures which will be applied to this application before starting the station.
Best regards,
efm
Best regards,
efm
RE: leak test procedures
Consult your appropriate industrial codes before you kill someone.
