Ceramic back-up bars
A fabricator is proposing using cramic back-up bars on CP moment connections. Says that's what he based his bid on. I never heard of them. Anybody know anything about them?
RE: Ceramic back-up bars
Assuming you will have nondestructive testing (either radiographic or ultrasonic) done on the welds, this should not be an issue. Please note that the welder should be qualified to this procedure in accordance with the required standard, such as AWS D1.1
Is a Manufacturer of ceranic weld backing
To Much info to post .
I can help with this.
rdrake@gullco.com
www.gullco.com
