Thermal Analysis of Glass Container Moulds
Can anybody advise,
I have been tasked to investigate the suitability of FEA tools to accurately predict the temperature distribution in cast iron moulds used to produce round & shaped glass containers. These moulds have axial cooling holes, with air forced through them. The hole positions/ sizes are variable so as to produce uniform temperature distributions.
Does any one use FEA tools in a similar environment? if so please advise.
RE: Thermal Analysis of Glass Container Moulds
My presumption is that you are trying to determine the temperature distribution and then the thermal stress effects which result from this. There are commercial codes that can do this in one step, but this is often more efficiently done as a two-step analysis: First one would determine the temperatures in the part, then one would use this output as an input for a thermal stress analysis.
The short is, your problem can be done, but the "how" depends on exactly what you are trying to accomplish (and of course what code you want to use).
