Ansys to Ideas?
Ansys to Ideas?
Dear Masters,
I have a problem with the ANSYS Interface! If I want to export an ANSYS file, I can do it, but if I want to import an ANSYS model, not result file, I can not import! In the older versions I could!
An another interesting thing: I installed an MS8 version on PC. I could import the ANSYS models (not result file!).
I had to reinstall everything on this PC, and the import interface is now different. Now I can import the rst file only!
OK, I know one way to import, but it is not to fast. (You need to analyse in the ANSYS and then you can import. Maybe!)
Does anybody know a hidden command or something to import the model data direct?
Thank you!
Irwin
Thank you!
Irwin
