problem with my full wave bridge rectifier!!!
hello everyone,
i prepared full wave bridge rectifier using 4001 diodes. the input is given from a tranformer 220/12v.
the output terminals r connected to a 4900 microfarads capacitor.now the voltage across the capacitor is 36v.i want it something around 12v.
can someone please tell me why is it showing 36v and how do i overcome it.
thanx in advance.
garuda
thanx in advance.
garuda
RE: problem with my full wave bridge rectifier!!!
TTFN
1)Measure the actual a.c. volts at the secondary - I've had a wrongly marked transformer in the past!.
2) As Irstuff says, the volts may be be higher if this is without a load. Don't forget that most small transformers try to compensate for copper and iron losses by "overwinding" the turns ratio so that it gives the right sort of output voltage at the rated load current. This may account for as much as 20% excess voltage at no load.
3) The previous explanantion is not likely to explain 300% overvoltage. One thing that might is if you have inadvertently connected the bridge to a centre-tapped 12V secondary, i.e. instead of being 0-12V connection to the bridge it's a 12-0-12V winding intended for a full-wave two diode circuit. This would give your bridge 24V input instead of 12V, and remembering that, off load, your capacitor will charge up to 1.414 x 24V (ignoring diode drops and allowing for overwinding) this gives about 36 volts!
4) You might want to check your transformer connections to make sure that you have not connected 220V to a 110V primary tapping, as this would also give you twice as many volts at the secondary.
Sounds obvious I know - but I speak from experience!
you are measuring the charge on the DC filter capacitor...try to put a resistor or light bulb with the
right voltage across and measure again..
dydt
I concede that point. It was a bit obvious but would certainly explain the result. (Of course if you ground the centre tap and use a bridge you get +/- 18V out).
You've been designing power supplies too long. That's cunning.
- there would be 24 V A.C., as first described BrianG in his answer, part 3)
There is lot of solutions. Take, for instance integrated stabilizer type 7812, don't forget add two capacitors cca. 1 microfarad to in and out pins against middle pin which is conducted to common, and minus lead from your capacitor.
A heat sink must be mounted on it, depends of current.
Another simple way (if you don't need stabilized voltage) is to change your transformer with one 9 Volts output voltage. It will produce around 12 V rectified. Use same diodes bridge (Graetz) and capacitor.
a rolling stone gathers no moss
Another reason is simple: 36 - 12 = 24 volts, and 2/3 of total used power would be dissipated into heat...
Much better result will be with input voltage of about 18 volts (if there is central point on transformer).
i am grateful for all of ur valuable suggestions. but this time i tried something else. i grounded one end of 4 diode and the other end to the capcitor which i grounded again.
also, i grounded centre-tap. this resulted in the burning of the grounded centre-tap wire.
need ur help once more. plz tell me why this has happened.
thanQ,
garuda
Your "modification" to the circuit shorted out 2 of the diodes, resulting in one half the transformer being shorted on one half cycle and the other half on the other half cycle. That is until the diodes overheated and failed short circuit, (which is what they do), and then the transformer would have been shorted all the time.
The bridge rectifier is probably fried as is the transformer. Draw the circuit and work it out.
