Transformer phasing
Transformer phasing
We use a 480/240-120V transformer, which is fed from two legs of 480V three phase. Now I know that each phase is 120 degrees apart on the primary. What happens to the phase sequencing on the secondary?
RE: Transformer phasing
Please do not confuse the primary supply with this as it truely has no bearing on the solution.
