Testing for 316 stainless...
At an old job, we had a small handheld little machine with an electrode and an aligator clip that we would hook up to stainless to find out if it was type 316 or not. It had a bottle of some type of liquid and a test strip. This machine would send a current through the test strip and the liquid, and it would indicate if it was 316 by changing colors. Am having trouble finding one of these or something similar. Does anyone out there know where to find one?
Thanks in advance,
Flores
Thanks in advance,
Flores
RE: Testing for 316 stainless...
ALLOY DETECTOR 2000 IDENTIFIES: Stainless steels (304, 302) 303, 316, 330, 416, 431, (420, 440) alloy 20cb, 17-4PH™, 17-14CuMo™, and many other stainless alloys. Corrosion resistant metals, 300 series, 400 series, monel™, copper nickel 70-30, copper nickel 90-10, nickel, hastelloy™ alloys, inconel™ 600 & 625, incoloy™, waspaloy™, stellite™, glass seal alloys and many others as well as carbon steels & alloy steels, Electro-plated or coated metals, cadmium, zinc, tin, nickel, chromium, gold & silver Aluminum alloys, (1100, 5000, 6000), 2011, 2024, 3003, 7075 and casting alloys. Copper, brass, naval brass, bronze, aluminum bronze, nickel silver, leaded brass/bronze, wrought and cast. Alloys listed above can be distinguished from each other. (Items in parentheses will test alike.)
Alloy Detector 2000 $785.00
http://www.alloyid.com/master.html
You may also be interested in the following [note: portable XRF units are highly expensive & may require a radiation license]
Thermo MeasureTech's XRF Analyzers are the preferred NDT (non-destructive testing) metals analyzers for the inspection industry for national safety and ISO compliance.
Quickly analyze 229 preprogrammed alloys or customize the list to your needs
http://www.thermo.com/eThermo/CDA/Products/Product_Detail/1,1075,14159-137-X-1-11949,00.html
Recognized as the developer of the first commercial coulometric tester, more Kocour testers are in use today than all other competitive makes combined.
http://www.kocour.net/home.htm
Passivation Tester 2026
Determines Passivation of Stainless Steels
http://www.koslow.com/2026.html
[I think this one is about $50K]
XLi Series Ultra-portable XRF Analyzer Fast, Non-destructive Chemical Analysis of: Solids · Liquids · Slurries · Soil · Ores Concentrates · Metal Alloys · Precious Metals
http://www.niton.com/xrf.html
Flores
Alloy Detector 410L $445.00
http://www.alloyid.com/stainless.html
If you have to persuade higher-ups for purchasing approval, they have a color photo that shows how 316 SS is distinguished from 304 by detection of Mo dissolved from sample: http://www.alloyid.com/index.html
