CIRA Concrete Code 1920
Does anyone here have a clue to what CIRCA is and were I can find a copy of it. To the best of my knowledge it is a Concrete Code, but no one seems to of heard about it.
RE: CIRA Concrete Code 1920
circa 1920.....it means around the year 1920.
I have the CRSI text your refer to (it is okay for the $10 purchase cost) but there is also a FREE Engineering Data Report #48 available in PDF format at CRSI ( http://www.crsi.org/PDF/edr_48.pdf ) . It covers similar stuff but no diagrams and plan drawings of the rebar/details of yesteryear.
You may have some fun with a 1920's building expecially if it was a flat slab. In the early 1900's there was great engineering debate about 2-way slabs without beams...C.A.P Tunner had a "mushroom reinforcement system" and there were other systems too like Kahn bars etc. But many were designed for much less than STATICS, like only 35% of statics yet they all withstood load testing.
Even upto ACI 318-1963 (not too long ago), it enabled you to design flat slabs for 80% of statics.
