Dimstyle override in acad 2002
I'm strugling with a problem that seams to happen when architect use a product called "architectural desktop". In my drawings the dimscale keeps defaulting to 96 and I'm constantly trying to delete the dimstyle override that seams to pop up out of the blue.
Has anyone else experienced this?
RE: Dimstyle override in acad 2002
Dimstyle overrides are like taking an existing rulebook and writing in new portions. You need to overwrite the overrides to change them back. If you are talking about the dimstyle settings, you can override the base settings in the dimstyle, and then do a "dim" - "update" to the dimensions globally if you desire. I hope this helps somewhat.
