Hyperlinks in drawing notes
We wish to have hyperlinks, in notes on drawings, to standard specification files.  SW allows an entire note to be hyperlinked.  We want to be able to have just a selected portion of the note (e.g., the file name of a specification) active to access the targeted specification.  In fact, it is desirable to be able to link to more than one file in a single note.
Can anyone suggest how this might be done?
TIA
RE: Hyperlinks in drawing notes
Looks like wanting more than just a hyperlink in a note is going to be a Enhancement request. You could add a word document but you would have to double click to get to the hyperlink.
Again if you want more than one link in a single note you will need to place an Ehancement Request in.
Unless someone has found a different way?
Best Regards,
Scott Baugh, CSWP
3DVision Technologies
credence69@REMOVEhotmail.com
http://www.3dvisiontech.com
http://www.3dmca.com
*When in doubt always check the help*
..and have you tried to remove the hyperlink from note?
You have to copy the content of note an recreate it in order to get rid of hyperlink.
