TR-55 Calculation for Time of Concentration
Could someone tell me how to handle a time of concentration in TR-55 to take into account a vertical wall, specifically in the case of water flowing into a quarry. In addition, could someone tell me where to measure your wetted perimeter and area in channelized flow. Specifically in a case where the typical ditch has 3:1 side slopes extending up for 4 feet; however, the stream flowing through the channel flows within a 1' deep x 2' wide rectangular cut in the base of the channel. Is the wetted perimeter assuming full flow conditions at the top of the 4 feet or is my area only the 1'x 2' rectangular channel in the bottom of the channel. Is there a good document that clearly describes how to measure channel flow geometrics? Any help would be greatly appreciated.
RE: TR-55 Calculation for Time of Concentration
Area and wetted perimeter are straightforward. The area of flow is what you want to calculate and the entire perimeter that is wet. Often easiest to just draw the cross section to scale and measure it.
King's Handbook of Hyadraulics is another "classic" reference.
For TR-55 it would be conservative to assume a travel time of zero down the wall. Unless the wall is hundreds of feet high the travel time must be very short; on the order of a few seconds one would think.
