Need info RE: a swivel for a steel hoist
I am designing a steel hoist system for a chain fall that can swivel.  It's a simple design for the most part, except for the fact that the hoist needs to swivel at least 180 deg. at the base.
            _______7'_______
            |                         V
            |                       4 kip
           10'
            |   __swivel here
       ___|/___
This is the first case like this I've come across, and the only solution I could think of was some kind of bearing.  The problem is that I don't have any info as far as:
     *the connection (to both the steel column and the concrete footing),
     *selection (size/type of bearing),
     *cost,
     *or even how to get the bearings.
Am I heading in the right direction with this, or should I do something completely different?
RE: Need info RE: a swivel for a steel hoist
In one of the shops I worked in, they had a crane-hoist design similar to what you're proposing.  The vertical beam was simply a pipe about 6 to 8 inches in diameter, and was inserted into a pipe base that was bolted to the floor.  The pipe base had gussets along the outside that was welded to a round plate on the bottom and in turn, this bottom plate was bolted to the floor.
The base had a couple of grease fittings.  This crane had pretty much the dimensions stated above, except our Yale hoist was rated at 1 ton working load.
This crane-hoist wasn't elegant in design, but maybe it will generate some discussion to help you out.
Flores
A jib crane is exactly right. McMaster-Carr catalog shows several styles w. capacities & dimensions. Search for jib crane or simply go to page 1256 & 1257 in online catalog.
http://www.mcmaster.com/
I don't mean to be technical; however, the crane you are refering to is termed "pillar-jib crane" as the jib is not mounted on a wall or vertical face but a pillar.  Considering that you are designing something unfamiliar with, I would suggest subcontracting out to a qualified crane manufacturer.  Though if you are interested, I have a one-page drawing of the said equipment in my WHE inventory.
mannyg:
   Thanks your input as far as passing the job off to someone else, but I would never have become an engineer if the job description was pumping out the same type of job over and over again.  Although this is the first pillar-jib crane that I've done, I don't see a problem with the structure itself.  Originally, my problem was getting the crane to rotate, but thanks to all of the responses I have a lot better understanding of how these cranes work.  You can never have enough information, so as far as that detail you mentioned, you can e-mail me or fax which ever is easier for you.  Thanks
sorlowski@fieldengrg.com
Fx: 1(508) 758-2849
