seawater piping
seawater piping
seawater piping
I am looking for alternative piping material other than 90-10 or 70-30 Copper-Nickel piping to install in the marine environment.  My basic point is to reduce the amount of Copper entering the environment.  Any help on this would be greately appreciated.
RE: seawater piping
A stainless with approx. 6% Mo does very well.  If you can avoid stagnant conditions and are at ambient temp. you could even use 304L or 316L ss, but you may get pitting if you can't be assured that stagnant times will be short.
RE: seawater piping
We use Fiberbond or Bondstrand as an alternative to Cu-Ni.  They can handle up to 300 psig.  If your pressure is not too high You can use fibreglass, PVC, ABS, etc.
RE: seawater piping
Hi Mathew1
I am not aware of your actual application.But if the initial cost is not a problem, then Titanium pipes will be the the ideal and ultimate.They don't conaminate nor get corroded.They are strong too. Well try them.
RE: seawater piping
Agree with keyardee. Titanium is the best option for seawater piping from the point of corrosion and avoiding Copper carryover and excellent strength to weight ratio. However Titanium welding would be a factor to consider as it requires special cleaning and atmospheric conditions.
RE: seawater piping
You can get lots of tips by looking at existing threads.
Search the eng-tips with keyword "Seawater"
Here's twop of them:
Thread378-18334
Thread177-2240
Or try even the
Saltwater corrosion engineering Forum Forum307
regards
Mogens
RE: seawater piping
Try Zeron 100. A duplex stainless steel.
RE: seawater piping
Thanks for the great information everyone has offered.
