How can I calculate the positive, negative and zero impedance values
If I have got the standard manufactures data for a cable. How can I calculate the positive, negative and zero impedance values?
Typical data given includes:
Maximum AC resistance - µOhms/m
Reactance - µOhms/m
Impedance - µOhms/m
Maximum capacitance - pF/m
Any help would be much appreciated
Reactance - µOhms/m
Impedance - µOhms/m
RE: How can I calculate the positive, negative and zero impedance values
If you need to actually calculate these valuec then look for a good book on symetrical components.
You should be able to get this information from the cable supplier. Otherwise, you will need to refer to reference text on developing sequence impedances of a cable.
IEEE Red Book or Buff Book should be of help.
