AutoCAD 2000 BACKS AN HOUR???
I was using ACAD2000 with Win2000 during 9 months. At last weeks, after 5-7 hours session, my drawing "goes back" about an 1-2 hour of operations. No way to recover the last modifications directly. Then I must to set "autosave" about 10min. and recover the backup.
Anybody solve this trouble?
T.Y.I.A.
RE: AutoCAD 2000 BACKS AN HOUR???
I have seen this happen when using the mstretch command from the Express tools.
I have had to stop using this command and the problem has never returned. Try to determine if a specific command is the one causing the undo problem.  Good luck!
Dear ybnrml:
You are right. I'd seen the bug ocurrs when I use BTRIM, BEXTEND and other commands from Express Tools. Have Autodesk a patch for this troubles? Securely not.
Thank you, man!!!
what version of the express tools do you have if you have the latest then check with outodesk cause every so often they update the code when a problem is found so make sure you have the latest if you havent bout or are not on VIP then you more than likely dont have the latest version
