TIP-Switching Parts in Assembly
5
Scenario:
You have an assembly (A001.asm), and you need to replace a part (P001.prt)with a new model (P002.prt). In the past, you would make a new model, and RELPACE it, and then REDEFINE the failed constraints.
Solution:
In the assembly, pick the part (P001.prt) that needs to be replaced, and right-click the mouse, select REPLACE.
Pick the option BY NEW COPY and enter a new part name (P002.prt). This allows the new part to automatically replace the original part without redefining constraints. You now have 2 identical, but unrelated parts.
Now you can open the new part and modify it at will.
Steve
http://www.3dlogix.com
RE: TIP-Switching Parts in Assembly
Thanks for the tip Steve.....
Looks like a nice technique for design iteration.
JW
Steve,
Thanks for the excellent time saving assembly tip.
Yogesh Birari
Hi Steve,
Very good tip. I gave you a star.
-Hora,
5
Wow, only 2 more stars and I get a free trip to Cancun!!
