POLOTING OF POINTS TO DETERMINE TRUE POSITION
WE ARE IN NEED OF A SOFTWARE (SHAREWARE OR PORFESSIONAL SUITE) WITH AN EASY TO LEARN INTERFACE WHICH WILL ALLOW US TO COMPILE POINT DATA (X,Y [MAYBE Z]) PLOT THE DATA AND OVERLAY OR SUPER IMPOSE A TRUE POSITION (CIRCULAR TARGET) GRAPH OVER THE DATA POINTS TO DETERMINE IF THE POINTS ARE IN TOLERANCE. IF ANYONE HAS KNOWLEDGE OF SUCH A SOFTWARE PLEASE COME FORWARD.
RE: POLOTING OF POINTS TO DETERMINE TRUE POSITION
Steven van Els
SAvanEls@cq-link.sr
If what you need is only an analysis of a set of points and a report on their compliance to the intended location, then Excel is certainly an answer: I can hardly believe that its 15 figure precision is not sufficient!
prex
motori@xcalcs.com
http://www.xcalcs.com
Online tools for structural design
Three will give you a defined circle
which you can quickly layout in acad
or such. All other points could then
be defined from you graphic ponts
perpedicular to this basic circle.
Or have I made your problem too simple?
