Managing Large Assembly
Hi All,
I am using TC11, NX11.
I have a NX assembly more than a million of parts, whenever i use to open the model it will take 1 to 1:30 hr to completely load the assembly, some times NX Crashes!!! again i have to open the assembly. Once the Model loaded i use to do the BOM Changes. How to reduce these loading time? I am using TC11, NX11. Whenever i open the models all the datum's, csys, loading up even after switching off the layers? i have used the best known loading options "Structure Only" " partial loading" "As Saved". But still i am facing lot of issues while loading. Can you guys please help me. Is this due to bad modeling standard, please share if there is any best standard of modeling & assembly.
