Load capacity of designed part
How to calculate load capacity of new designed part? For e. g washer having OD .250 and ID .125 THk .060 material is Aluminum
RE: Load capacity of designed part
What is the function of the washer?
If the washer is part of a threaded fastener assembly I would not want the washer to deflect "cone" very much at all down into the through hole, either elastically or plastically . I also would not want the fastener head to embed into the washer, either at installation, or over time, as that would result in reduced fastener preload and clamping.
Failure point minus safety factor.
