fortran compiler for parallel programming.
Any available free fortran compiler for parallel programming
RE: fortran compiler for parallel programming.
If you are just using openmp, try gfortran.
gfortran will also work with cuda - that is, if you have an nvidia graphics card. It uses the graphics card as a parallel processor.
If you do not have an nvidia card, try gfortran with opencl.
