Slip-Critical Joint Inspection
Hello everybody,
Can someone tell me how does the inspection of slip-critical joints look like? My understanding is, according to AISC, that "faying surfaces shall be verified that they meet the requirements as specified in the contract documents prior to assembly of the joint.." I am gonna have a project (shop drawings), working for steel fabricator, where EOR specified all connections as slip-critical..it's a 4 story steel frame 50'x100'. So inspection wise, does that mean that all plates have to be inspected prior assembly ? Bolts pretensioning is clear to me. I've got to say I've never seen SC bolts specified as typical bolt for the frame..Anyways, Thanks in advance !
RE: Slip-Critical Joint Inspection
Dik
