Find the maximum of a regression line in Excell
I have 4 points in a graph and i can find a tendencie line but when i try to find a 4th degree regression line with the parameters m1,m2,m3,m4 and b it turns out to be a very bad aproximation. I am trying to find the right equation in order to find its maximum.
Does anyone know what is the problem or if it is impossible to perform in Excell?
RE: Find the maximum of a regression line in Excell
Why use a 4th degree polynomial?
You could have a linear relationship with 4 points. I think you don't because you spoke of maxima.
Anyway, if you have 4 points, you can fit at the most a 3rd-degree polynomial (r=1 for this case)
Ari Constancio, Chem. Eng.
ari.constancio@netc.pt
http://www.terravista.pt/ancora/1588
Are you sure you're looking for a regression?  It sounds more like you're looking for an inflection point (maxima).  If that's the case, take the first derivative of the line connecting the points.
Maybe I wasn't very explicit.
My problem is findind the regression line. I mean, a good regression line, because the ones that i tried weren't good aproximations.
Maybe it's not possible to be accurate with standard Excel functions.
