KWA on error deactivate feature
Hi everyone,
I have one question for you guys, is there a way in KWA licence to test an operation if it's work or not? From what i've seen the error handling works if i create the operation inside a rule thet i can put the rule to test it and after that modify it. Is there a way to make this testing with a operation that is already created?
Example: i want to instantiate some geometries; inside this construction i have a blend that in some cases does not work; what i want to do with the rule is to deactivate it if the operation does not work.
Thanks for the future felp!
