ASME B16.5 1977 and A181 gr 1
Can anyone confirm ANSI/ASME B16.5 1977 edition lists A181-1 Flange material as group 1.4 which is 620 psi at 100°F?
RE: ASME B16.5 1977 and A181 gr 1
The answer is "Yes" and FYI they referred to it as A181-I (not a "dash one", but a "dash eye" instead).
Hope this helps.
Thanks for the info.
Two other questions
1) Why did 16.5 delete "Non shock" verbiage from code book. In regards to listed flange pressure
2) would you happen to know MSYS for API 5 L in B31.3 1984 edition
Thanks again
