Simulation of a distillation column
Hello for ALL
When i do a simulation of a distillation column, how can I use the cold feed stream as a coolant to OVHD condenser within the same file in Aspen Hysys or I can not ?
Thank you in progress..
RE: Simulation of a distillation column
there are different ways to do this, I use a different software (Prode) and I do not know the details with Aspen but sure there is a way.
