Electric resistance welding and PWHT
Hi all,
Is it needed to apply pwht after electric resistance welding of studs for A335 P9 material studded tube manufacturing?
I made a search but could not find any relevant standard, is it mentioned in any standard?
Thank you in advance.
RE: Electric resistance welding and PWHT
Thanks.
Pradip Goswami,P.Eng.IWE
Welding & Metallurgical Specialist
ca.linkedin.com/pub/pradip-goswami/5/985/299
(5) for welds attaching nonload‐carrying studs or insulation attachment pins not exceeding 1/2 in. (13 mm) in diameter when using an automatic arc stud welding or automatic resistance stud welding process
and metengr is there any code that recommends pwht?
I found 2001 version of section I for power boilers and there is a limitation of 4" on that one.
there is a link for screen image of 2001 edition
