Get node temperature
I get node temperature via command
CODE --> APDL
*GET,Par,NODE,N,NTEMP
which works. But if I want to do same for n load steps
CODE --> APDL
*GET,Par,ACTIVE,0,SET,NSET
*DIM,Par2,ARRAY,Par
*DO,i,1,Par
 SET,i,1
 *GET,Par2(i),NODE,N,NTEMP
*ENDDO
I get only the last time step temperature. The result file is from Ansys Workbench (temperature field is imported via external data). Is it possible get node temperature from all load steps?
Best regards
JK
RE: Get node temperature
Hi JK,
As far as I can tell, I don't see any problem in your script. Perhaps look at other possible source of error?
Does your analysis have multiple load steps? SET,LIST
Kind regards,
Jason
thanks to all for tips. I use
CODE --> APDL
*GET,Par2(i),NODE,N,BFE,TEMP
instead of
CODE --> APDL
It works pretty good. But there is an unexpected situation. If temperature field is not declare in some load step, previous temperature field is used. I have to investigate this case and try to fixed that.
