NX Assembly Problem
NX Assembly Problem
RE: NX Assembly Problem
Check you reference sets, you probably have extra geometry in the model reference set, The reference set to check for geometry would be in your part, also check to see what reference set your assembly is using.
I think SDETERS has it right. Just to add on, note that with the default settings, NX will create a "MODEL" reference set and automatically add any solid and sheet bodies as you create them in the file. It looks like an extracted body was added to your reference set, causing it to show up in the assembly.
www.nxjournaling.com
