HybridShapePointCoord.RefAxisSystem problem
I have a Coord point with a Reference Axis system. I would like to remove that Ref Axis System
CODE --> code
Dim oPT As HybridShapePointCoord
Set oPT = CATIA.ActiveEditor.Selection.Item(1).Value
oPT.RefAxisSystem = Null
does not work. I also try to declare a Ref then pass the empty Ref object to the oPT.RefAxisSystem but error again...
Does someone know how to remove the axis Ref? VBA or EKL is welcome. Using 3DX2016X
Eric N.
RE: HybridShapePointCoord.RefAxisSystem problem
Would isolating the point not solve your issue?
and then redefine it with its own coordinates? if links follow i don't mind which way... i will see
Eric N.
manually when I Isolate the point and bring it back with coordinates, the refaxis comes back...
Eric N.
This may not be optimal, but would setting all Axis Systems in the Part as 'Not Current' before be a viable solution?
i ll try, but are are looking into opening a SR now...
Eric N.
