Assembly load options
Hello
Everytime i want load or open a new file i have to go to assembly load options and change "From Folder" to "As Saved".
There are a way to make this change default, so i dont have to close everytime i forget change this option?
I work with NX11
Rúben Silva
I work with NX11
Rúben Silva
RE: Assembly load options
press that . done.
IF you desire, you can set a environment variable such that this file is stored on a server or similar.
( This variable can also be set locally to override a company setting...)
UGII_LOAD_OPTIONS = \\server\directory\filename.def
Tomas
