LM-1 Flow rate unit ?
Hi
Has anyone come across this unit of Flow rate , Lm - 1 , we have a spec for 1 -5 Lm-1 for a flow rate but not sure what this is,and have an equation for converting it to L/min
thanks
chris
RE: LM-1 Flow rate unit ?
Lm-1 = liters/minute.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Someone is being a bit too scientific for their own good, but I would interpret this as litres per minute
Instead of l/min, they've gone the scientific notation which is l min-1 Only they haven't put the -1 in superscript....
Thats what i thought but thanks for clarifying :)
You "have an equation for converting it to L/min", so what is this equation?
Good luck,
Latexman
Is it just me, I would say it's a nonsense as a flowrate, simple solution is ask who wrote the spec to clarify.
If you don't understand what it means how can you make any sense from it?
