Looking for fast acting semiconductor fuses
We have an expensive piece of equipment that can withstand only about 4,000,000 A²s let through energy.
There is no circuit breaker fast enough to clear a fault that quick, so we would like to place a fused isolation switch right next to that device. The semi-conductor fuses should be rated 800A for the device.
Would you be able to point out an isolation switch and plugin fuses that can do this job?
RE: Looking for fast acting semiconductor fuses
http://www.gdrectifiers.co.uk/uploads/Mersen_Fuses...
The fast thing I think for arc flash is dropping a crowbar.
